Re: F-20 1939 Rod Bearing
Posted by El Toro on November 22, 2010 at 13:03:27 from (108.3.200.96):
In Reply to: F-20 1939 Rod Bearing posted by Josh Blackburn on November 22, 2010 at 11:48:19:
Try Rice Equipment in PA at 814-227-9200. You need to specify whether it is standard or you need undersize bearings if the crankshaft has been ground undersize. Hal
PS: You may need to measure the shaft or have it measured.
