This is going to take sometime. I have sheets full of Napa part numbers for many Farmall tractors. Here are the parts for a Super A.
Farmall Super A Napa part numbers Oil Filter 1172 Head Gasket C-113 7732S Head Gasket C-123 7900S Timing Cover Gasket Set TCS45115 Manifold Gasket Set MS8797B Rear Main Seal Set BS40023 Oil Pan Gasket OS3303C Valve Cover Gasket VS3300C Full Gasket Set C-113 FS7732S Full Gasket Set C-123 FS7900S Fan Belt 2528333 Water Pump Re-Man 598128 Spark Plugs Autolite 3116 Plug Wires 700172 Ignition coil 6Volt IC7 Distributor Cap IH350 Distributor rotor IH300 Condenser IH200 Points CS1600 Magneto Cap IH351 Magneto Rotor IH301 Condenser Magneto IH201 Ignition Coil – Magneto IC1851 Generator Belt 259279 Starter- Remfd, Delco Remy; 6 volt 91013679 Starter Switch ST500 Wheel Bearing Cone - Outer - Front Wheel BR09074 Bearing Cup outer Front Wheel BR09196 Wheel Bearing Cup Inner 15250X Wheel Bearing cone inner BR15118
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
