The main reason using it in TA under heavy load will shorten the life is that you must remember the whole secret to the unit is the overrunning clutch. This consists of a ramp with rollers that are forced into the wedge of the ramp. The harder you force those rollers from heavy loading the sooner they groove deep enough into ramp so they cannot move enough to securely grip the carrier to prevent it from rotating backwards. When carrier rotates opposite direction from input shaft, the out put shaft stand still so, no drive. Of course the planetery gears wear more also when heavily loaded but they are normally not the first parts to failure. They will usually last two or three ramps and carriers. Good quality gear lube like HY-tran will minimize the wear and allow those rollers to keep moving freely longer.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
