Re: Re: Super W-6 Loader/Bleeding Hydraulics?
Posted by Patrick Skelley on June 28, 2000 at 14:30:16 from (207.144.72.2):
In Reply to: Re: Super W-6 Loader/Bleeding Hydraulics? posted by ltf in nc on June 28, 2000 at 13:25:48:
No separate pump. I tapped into the factory live hyd. pump. Plenty of oil in the reservoir, and oil seems to be getting to the cylinders (I cracked a couple fittings), but no movement when I move the levers. The spool was set up for single-action cylinders, and I removed the plug and added a fitting to provided for double- acting cylinders. Did I miss some sort of internal modification to the spool to make it operational for double-acting cylinders?
Thanks!
Patrick
Post A Followup
: Re: Re: Re: Super W-6 Loader/Bleeding Hydraulics?
