Chaz drain all the oil that will drain out the plug under the TA housing. Then remove the lines from the plate on left side of the TA housing. Then remove the 3/8" size capscrews from around the out side of that plate, the plate has dowel pins so it might come loose a little hard, the 2 pumps will come with the plate. The pump with the drive gear is the hyd pump the piggy back is for the power steering. Hope this helps.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
