Re: Original Engine in a Super A or not?????
Posted by tempola on November 24, 2010 at 11:12:36 from (207.119.214.51):
In Reply to: Re: Original Engine in a Super A or not????? posted by AL Farmall Boy on November 23, 2010 at 20:59:50:
It looks like possible a later model engine, as you have traces of yellow paint.
it is most likely from a super A or C,or indrustal because the water pump is present.
it's not a powerunit engine, but that "indent" in the head below spark plugs 2 and three looks strange. the tube going into the rocker cover is another way to supply oil to the rockers. I suspect that head has been repaired and blocked off in the oiling area.
I don't think it's from a 140, because the 140 had a more conventional water pump(I think)
If you are not going to use the tach drive on the distributor, I'd like to buy it. I would supply you with a block off plate.
Andy
