Re: Carter Carb on 100 woes
Posted by gene bender on November 24, 2010 at 12:18:03 from (67.55.227.196):
In Reply to: Re: Carter Carb on 100 woes posted by Marv on November 24, 2010 at 05:26:58:
Is your dist up to snuff. Had a sevice call said it runs rough and so forth. I took the timing lite and went from one plug wire to the next found out two of them werent firing all the time. A rebuilt dist solved the problem.
