Re: Farmall 560D batteries
Posted by 504 on November 24, 2010 at 18:13:18 from (64.111.61.44):
In Reply to: Farmall 560D batteries posted by Jwg on November 24, 2010 at 18:04:47:
If you are using two 12 Volts, Pos cable to Pos and neg to Neg will still give you 12 volts. Two 6 volts, Pos from one battery to Neg on the other will give you 12 volts. (Pos to the starter, Neg to ground and then hook up the other battery as needed.)
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
