Re: Fast hitch, good or bad? would like your input please
Posted by IH fan on November 25, 2010 at 16:16:53 from (70.245.162.146):
In Reply to: Fast hitch, good or bad? would like your input please posted by 36F30 on November 25, 2010 at 16:02:42:
Converting your F-H to 3 point isn't going to gain you anything. The big drawback I could see to them, was the control location on the side of the dash instead of beside the seat. Also the draft control is not the best on the F-H, compared to most 3 point set-ups... that won't change if you convert to a 3 point. Of course there is no draft control on a pull type either, so that is a wash.
