Re: Fast hitch, good or bad? would like your input please
Posted by bkpigs on November 25, 2010 at 16:30:40 from (75.132.236.65):
In Reply to: Fast hitch, good or bad? would like your input please posted by Matt (NEIA) on November 25, 2010 at 16:02:42:
It is a good working concept. You can use 3 point equipment with it if you have the adapters. It is very versatile and handy for quick changing of implements if they are of the fast hitch style.
As far as pull-type or mounted, I have no experience with pull type but I would say that there is a reason all newer plows are mounted or fully mounted. You have much better traction control and easier to manouver (sp?) especially in small fields.
