Re: Inter-changeable head?
Posted by D Slater on November 25, 2010 at 18:02:30 from (184.15.11.88):
In Reply to: Inter-changeable head? posted by 1949H on November 25, 2010 at 13:27:55:
It will work, but if its a original 49 H head some 350 fire crater and raised top pistons will hit the head. If you have the tools and know how and also a 300 head to compare with the H head, the H combustion chamber edge can be blended to clear 350 fire crater pistons.
Most all the heads have a cast # under the valve cover. May be able to give a better answer with head numbers and piston type. If the H was a gas tractor it probably came with a 8043 DC head.
