the amp output of a converted 6v to 12 v generator will be one half. The power output is the same. If you change your lights to 12 volts same wattage bulbs and your starter actually draws less amps when starting they are going to be in the same ball park at battery recharge.
Cooling needed on the armature is going to be less with 12 volt than with 6 volt output. As there is air flow through the generator to keep the field windings from overheating, I would certainly give this a try if I have a generator in good shape. The brushes should have less maintenance as there is less current through them. The only issue I see at this point is the field winding current.
If you were going to convert to 12 volts and garbage your old generator anyway the only downside is the cost of the regulator and the fiddle time. George
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
