Re: bn will not start
Posted by tempola on November 26, 2010 at 09:32:37 from (207.119.118.105):
In Reply to: bn will not start posted by TODDHECK on November 26, 2010 at 08:22:45:
sometimes if the starter gear and or flywheel gear is worn, it can cause a lockup. see if the engine is free, if not take the starter loose and see if it is free(we all hope so) if so, and all is OK with the starter, bolt it back up a little loose. but only leave it like that until you fix it, or you will crack the housing.
I had a super c go BANG once. the ignition rotor broke and threw it out of time.
Andy
Today's Featured Article - Buying your first tractor: The People You Buy From - by Chris Pratt. If you are a first-time buyer, chances are that you are likely to take the word of the seller on things. This is where the problems start... You have reviewed your implement needs and determined the size of machine that will fit the bill and even made a list of the most desirable models. You checked on the availability of a 3-point hitch for the machines on the list and advertised in your local classified paper with so ... [Read Article]
