Re: 2424 - What Size Front Tires?
Posted by Owen Aaland on November 26, 2010 at 12:33:35 from (65.165.246.145):
In Reply to: 2424 - What Size Front Tires? posted by Wardner on November 24, 2010 at 05:19:28:
You can turn the rims around to get more clearance but the tractor will suffer for it. It causes harder steering and can lead to broken spindles.
If you follow the center line of the spindle down to the ground you will find that it meets the ground about the middle of where the tire contacts the ground. That allows the wheel to pivot on that spot when the wheels are turned. If you reverse the rims the center line of the spindle will not be in the center of the tire. When the wheels are turned they can no longer just pivot but must also roll. This increases the effort needed to steer.
Also by moving the wheels out away from the center line it changes the forces on the wheel bearings. As originally designed most of the load is carried on the larger inside bearing. With the wheel moved out the load moves more to the smaller, outside bearing. This makes the horizontal part of the spindle act like a lever and greatly increases the forces on the angle of the spindle. This can lead to spindles breaking at the inner end of the large bearing.
