Re: bn will not start
Posted by old on November 26, 2010 at 13:15:42 from (4.245.11.168):
In Reply to: Re: bn will not start posted by TODD HECK on November 26, 2010 at 10:29:27:
Depends on if that starter has been rebuilt for 12 volts or if it is still a true 6 volt starter being used in a 12 volt system. A true 6 volt starter will work just fine on both 6 or 12 volts but a true 12 volt starter will not work on 6 volts. That said there is probably few if any true 12 volt starters made for an A/B/BN but one never knows what some one has done. Either way you can try it and if it spins over then it is a 6 volt one if it does not or spins super slow it is a 12 volt one and will not work on 6 volts
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and ... [Read Article]
