Al, thanks for sharing as that type makes sense as far as hooking up. Unlike fast hitch implements which have the prongs set at a specific spacing (28" + or - 1/4" or so) 3 point implements don't seem to have that tight of control on their spacing. Those 3 point arms you kindly shared in your photo would need some type of constant spacing between the hook-up lower pins to work. I guess that piece on the top of the prongs slides back over the pin once raised to lock onto the implement. Some of those 3 point implements are just torture to have to fight with to hook-up to the tractor and like my disc mower I just leave it on the tractor for the hay season as it's no pleasure either and it's easier then a lot of equipment. A smooth level concrete surface is certainly a big help too. Back in the early 1950's when the Ford N series tractors were common they couldn't handle anything which couldn't be moved around fairly easily by one person and guess the usage on those smaller tractors is what led to the wide acceptance of the 3 point system. It's a problem when using the later big heavy stuff which reguires some real muscle to move around. Thanks again and I didn't mean to start s rant, Hal.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
