Hello Dr Bert: Thank you.. So that's what it looks like. Nice job of Changing the ratio between steering wheel to amount front tires moves. (I didn't save original post) I always felt the standard 3 rib front tire turned easier then a vehicle tire since there is less ground contact area, if you have 6 ply 3-rib tire and higher air pressure. (I am talking about when the tractor is moving at least a little.) If those are 4 ply tires, you still could get by with somewhat higher air pressure?
Brother inlaw put on an oversized steering wheel on his loader tractor years ago and it helped. If I am using a non power steering loader tractor, I will often drop down into the lowest gear for making sharp turns just to keep front tires moving a little while turning. ag. Thanks for posting a picture of what you did. Looks good.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
