Posted by John T on November 27, 2010 at 07:32:47 from (66.244.97.31):
In Reply to: Super C battery cables posted by ffinmich on November 27, 2010 at 07:05:53:
If it was converted to 12 volts but you kept the 6 volt starter, Bob M and I had opinions on this a good while back, BUT WE BOTH AGREED ON EITHER BEING A GOOD THING TO DO.
I'd EITHER use lighter gauge, say No 4, battery cables ORRRRRRRR use a lighter duty smaller CCA battery SO AS TO DROP A BIT OF VOLTAGE TO REDUCE SUCH A RAPID HIGH TORQUE KICK IN TO PROTECT THE STARTER DRIVE AND/OR FLYWHEELT RING TEETH. Even a smaller battery or 4 gauge cables will still crank a little C plenty fast enough when 12 is applied to a 6 volt starter.
When you apply 12 volts to a 6 volt stater sure she spins good n fast (and Ive done it n never had any problems) but it can be a bit tough on "some" types of starter drives. The use of a lighter less CCA battery or smaller gauge cables can lessen that problem.
Usually for 6 volt with 6 volt batteries I recommend 0 or 00 gauge cables TO LESSEN VOLTAGE DROP but 12 votls on a 6 volt starter is a bit different. BUTTTTTTTTTTTTT if the starter was converetd to 12 volts, then Id go ahead and opt for say 1 gauge cables on a C, bigger if an M.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too.
... [Read Article]
Latest Ad:
[More Ads]
