Posted by Janicholson on November 27, 2010 at 18:49:17 from (67.72.98.45):
In Reply to: need help with 424 posted by ross t on November 27, 2010 at 16:44:09:
Yes. Check to see if the distributor is turning when cranking. If not it will need to have parts taken off until the broken pieces are discovered. Put #1 piston in compression stroke (thumb over the spark plug hole and crank in short bursts till the thumb is blown past. Then align the timing marks for TDC without going past. The rotor should now be pointing directly at the #1 cap tower connection. If not it is off time. Jim
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
