That type of valve problem is caused by the type of engine oil being used. Those engines are very prone to carbon buildup on the exhaust valve stems. When put under a heavy load the valve temperature will increase causing the valve stems to expand. The carbon on the stems causes the valve to hang open a little and the combination of the valve head temperature and the oxygen in the fuel mixture leaking out past the valve on the compression stroke has the same affect as cutting the valve with a torch. The solution is to use the later style valve stem seals and, most important, to use a low ash oil.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
