Re: Would this haul thet?
Posted by NDS on November 29, 2010 at 04:57:04 from (98.81.26.44):
In Reply to: Re: Would this haul thet? posted by minnesota red on November 28, 2010 at 21:24:49:
Last time I looked farm truck exemption was for 150 air miles from home but whatever the distance that is for CDL regulations. Farm trucks are not exempt from brake, lights, tires, weight, tie down, speed and such regulations.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
