Re: Would this haul thet?
Posted by mkirsch on November 29, 2010 at 05:36:38 from (64.80.108.55):
In Reply to: Would this haul thet? posted by chuck41 on November 28, 2010 at 12:33:58:
That's a requirement of the receiver on your truck, not law.
The factory receivers on even 3/4 and 1 ton trucks these days are GARBAGE. If you're lucky, the weight carrying capacity of the hitch is a whopping 1000lbs without an equalizer hitch.
To carry more than 1000lbs you need an equalizer hitch, and then you're limited to 1250lbs, or sometimes 1500lbs.
It's pathetic. The manufacturers don't even equip the trucks with hitches capable of towing what the truck is rated to tow!!!
