Re: Old bolts...
Posted by Janicholson on November 29, 2010 at 06:53:59 from (199.17.6.126):
In Reply to: Old bolts... posted by mkirsch on November 28, 2010 at 19:14:24:
Heat treatment, and grade of bolt, and the alowed amount of mill scale was controlled by IH to high standards. (Dot bolts are an example of the philosophy. That might be a factor in their remaining servicable. Jim
