Re: Starting issues
Posted by Brownie 450 on November 29, 2010 at 10:19:55 from (66.43.241.198):
In Reply to: Starting issues posted by JTKY on November 29, 2010 at 06:22:28:
Do you have a multi-meter [preferably analog]? Connect it to the coil primary terminal which comes from the on-off switch & ground [frame]. See what the voltage does while cranking the engine. If it drops substantially, look for a bad switch or bad connection on a wire from the battery clear up to the coil/ distributor. We're assuming you've checked the points & condenser.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
