Re: 1066 lost hydraulics
Posted by Owen Aaland on November 29, 2010 at 18:19:55 from (65.165.246.145):
In Reply to: 1066 lost hydraulics posted by Bill Lisbon on November 29, 2010 at 17:22:00:
Unlike the gear drive tractors, the Hydro's use a two piece lower IPTO shaft for the hydraulic pumps. There is a coupler between the two shafts where the center section and the rear frame join together. If that coupler is worn out or broken it would explain the symptoms you are describing.
