The sleeveless C221 most likely came out of a combine. The other difference you will find is the sleeveless block will not have threaded holes in the back of the block. You will need to use longer bolts with nuts.
When changing piston style you have to make sure that your head will work with the new pistons. Early heads work only with the stepped pistons. They are flat over about 1/2 of the piston and then the rest is combustion chamber. The combustion chambers on the later heads start to go up at angle near the edge of the piston and have the necessary clearance for the Fire Crater pistons.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
