Posted by caterpillar guy on November 30, 2010 at 06:23:08 from (66.188.53.165):
In Reply to: 1066 lost hydraulics posted by c-man on November 29, 2010 at 17:22:00:
If you remove the cover under the clutch .You can see if the splined shaft is turning, in the back of the clutch with tractor running. If it turns your trouble is farther back. If not then it is in the clutch either the pressure plate hub shot or the splined shaft. Splitting will be the order for that. You can also pull the plate under the speed trans after draining oil out. Bump starter to see if the gear is turning in bottom front on through shaft for PTO.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
