Re: Starting issues
Posted by Janicholson on November 30, 2010 at 07:23:08 from (199.17.6.25):
In Reply to: Re: Starting issues posted by JTKY on November 29, 2010 at 17:28:02:
first use of a resistor almost always causes some smoke. I think you said you changed the coil. So I assume it was a "for use with external resistor" coil. if not, it could be low on spark from the true 12v coil and a resistor.
Make sure the points are set at .020". Jim
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
