Super C Carb problem?
Posted by Idaho Ron on November 30, 2010 at 18:55:59 from (208.98.157.18):
I noticed that my SC would bog down and miss a little when I used the Hydraulics or if I let out on the clutch. Just idling it was running ok but not great. I cleaned the plugs rotor and rotor cap. That usually does it but this time it still is not running good. I idled it up and pulled the rod for the governor and it bogged down. I took off the gas bowl and cleaned the screen and bowl. I noticed that it would not fill up when I turned on the gas at the bowl. I took the bowl back off and turned the gas on and it flowed well. SO I put it all back together and took off the line at the carb. I turned the gas on and it flowed fast. I am thinking that something in the carb is not working and the gas flow is locking up. What do you think is the problem? Thanks Ron
