Re: 400, 450 PTO
Posted by Wardner on November 30, 2010 at 19:13:51 from (4.154.255.78):
In Reply to: 400, 450 PTO posted by Andrew Z on November 30, 2010 at 19:01:32:
No, your friend is screwed.
IPTO starts with the spring retainer/cover on the main clutch pressure plate. Everything else is different all the way back to the PTO shaft sticking out the back of the tractor.
Everything can be swapped out if one is so inclined.
