Re: 806 quit running
Posted by oldtanker on November 30, 2010 at 20:17:04 from (66.228.255.223):
In Reply to: 806 quit running posted by LN on November 29, 2010 at 16:51:48:
Good lesson for you here and great advice. The lesson is trouble shoot first. Nothing worse than replacing a bunch of expensive parts to find out it was a plugged fuel line.
Your system is gravity feed to the pump (Actually because of gravity it feeds to the injector pump well enough that the pump dose the work from there). After all the tank sits higher than the injector pump so no need for a lift pump.
Rick
