Re: Farmall F-20 clutch
Posted by 36F30 on November 30, 2010 at 20:30:41 from (71.214.217.123):
In Reply to: Farmall F-20 clutch posted by NDS on November 30, 2010 at 19:13:32:
Very common problem on these old girls. I always block the clutch pedal down with a chunk of wood during storage and plug the timing hole with steel wool to keep the mice out. Mouse crud can really stick em. You can take the clutch out in about 15 minutes and you will find the disc rust bonded to the flywheel. Take a twisted wire wheel on a 4.5 inch grinder and buff the flywheel and pressure plate clean. Then clean and lube the finger pivots, clean all your wd40 off the friction surfaces and slap her back together.
