Re: IH 674 hyd problems. Something new to me
Posted by Little_Willy on December 01, 2010 at 01:37:47 from (166.216.162.50):
Hello Bernard, My brother and I have been working on this same tracktor with some of the same simtoms. It busted the pump housing the first time. We replaced the pump with a new one. When we started it up to check the pressure the hydraulics work for a little while then stopped working. We removed the pump and itt had blown the pressure side o-ring and the pump cover seal. It seems like the pump is deadheading. We have ckecked the flow divider valve and the releife valve. Also check the dump valve under the seat. Do you have any ideas or suggestions as to what to check next ?
Thanks in advance
Greg
