Re: Farmall H no load engine miss/kinda long
Posted by Janicholson on December 01, 2010 at 06:11:59 from (199.17.6.126):
In Reply to: Farmall H no load engine miss/kinda long posted by Gene Norman on November 29, 2010 at 19:21:55:
If it were mine (and i had invested as much time in it as you) I would replace the manifold with a IH used original. Though it would not be the easiest replace to check solution, it would make sure the manifold was distributing fuel correctly. I assume the load screw has been adjusted to attampt to clear it up with no success. Jim
