Re: tractor implement
Posted by Janicholson on March 12, 2009 at 08:43:53 from (64.83.225.108):
In Reply to: tractor implement posted by Tony_Idaho on March 12, 2009 at 08:02:01:
If the disk you have is a deep tillage implement with the front set of blades in one direction, and the rear in the other direction, that is about right for it (maybe a bit small). if it is a 4 gang disk two fronts different opposite angles, and two reae mirroring the front, then it is small for the 450. A 10' disk harrow is reasonable in moderate soil, or 8' in heavy clays.
It is likely, as noted, a cultipacker being used behind the disk. JimN
