Exhaust pipe comes through on the right side of hood on a diesel. Diesel uses a bigger diameter oil filter than what seen in the photo, plus it looks like a gas. Cast brake housings can be seen pretty good in the lower photo with 5 bolt mounting. All M except the last month or two built used steel brake covers or a add on disc brake attachment that used 3 bolt mounting. Housing between engine and transmission is made for a belley pump hydraulic system and is shorter than a SMTA one. If the serial # is readable a Super will have the letter F or L before the serial #. Block should have C 264 in raised cast letters above oil filter housing.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
