Re: 52 h farmall
Posted by Stuart on December 01, 2010 at 21:15:51 from (64.198.86.189):
In Reply to: 52 h farmall posted by Jim iowa on December 01, 2010 at 21:11:42:
Its either in your distributor gears. or most likely because it has live hyd pump, its the cam gear or gears up front that drive it. I thought I was told once that when a non live hyd tractor is fitted with a live pump that the front gears have to be heavier. Maybe someone with more knowledge of this will chime in, hope this helps.
