Re: 52 h farmall
Posted by rustyfarmall on December 02, 2010 at 05:44:50 from (209.152.78.140):
In Reply to: 52 h farmall posted by IH fan on December 01, 2010 at 21:11:42:
The vertical Delco distributor has a cover plate that can be removed,(the coil will be mounted to it) and I think this will allow you to see the gears that drive it, but I think the problem might be deeper. The vertical Delco was quite often used when adding a live pump to prevent the spark plug wires from rubbing on the oil filter canister.
