Re: 52 h farmall
Posted by D Slater on December 02, 2010 at 05:56:46 from (184.15.20.83):
In Reply to: 52 h farmall posted by Jim iowa on December 01, 2010 at 21:11:42:
If the pump is a M&W with the hydraulic lines attaching to back side of pump. Engine is already out of time so pull the distributor and check gear and pin to shaft and also see if the distributor drive gear is turning. If the distributor drive gear is not turning you will need to check the drive on the front of pump that engages the slots in the ignition drive. If still no problem the main drive gears under front engine cover would be a suspected problem. You could use a IH distributor in the vertical position with the M&W pump I mention.
