Re: 52 h farmall
Posted by glennster on December 02, 2010 at 05:59:09 from (76.222.60.13):
In Reply to: 52 h farmall posted by Jim iowa on December 01, 2010 at 21:11:42:
check the drive gears in the distributor at the 90 degree housing. if you have not greased them in a while, i suspect they are stripped out. the '42 m i have did the same thing. if those gears are ok, pull the valve cover and crank the engine over and look for movement in the valve train. if the valves are not opening and closing, it could have sheared the cam gear. the 52 h should have the heavier cam gear tho.
