Re: 10-20/w-30 help
Posted by justin on June 30, 2000 at 14:38:54 from (12.34.184.80):
In Reply to: 10-20/w-30 help posted by K C Bob on June 30, 2000 at 12:00:14:
The engines are almost the same, but not.. The sleeves are the same, but don't replace a piston unless the ring widths are the same for each engine.. as far as the rest of the engine goes, the main and rod bearings are the same, and if I remember right the crank and connecting rods are the same also... The oil pan, camshaft, oil pump will also interchange... The main difference between the two engines is that the W30 has a water pum, which makes the bock and head design to differ from the 10-20 style..
Post A Followup
: Re: Re: 10-20/w-30 help
