Re: More questions on 39 M
Posted by gene bender on December 02, 2010 at 10:48:51 from (67.55.227.196):
In Reply to: Re: More questions on 39 M posted by Baelee05 on December 02, 2010 at 07:45:01:
The cut-out will work just fine if all things in the charging circut are grounded. You have three terminals one is the batt from the sw the gen terminal goes to the A term on the gen and the Field goes to the Field on the gen. Then a wire goes from the Field terminal to the lite sw at the bottom of the sw then the H position will provide hi-charge. With the mag you dont realy need hi-charge unless you are just using the tractor for short times as your batt could get weak from many starts. Is your gen still original and has the original tag.
