Posted by Owen Aaland on December 02, 2010 at 14:01:44 from (65.165.246.162):
In Reply to: IH 460 issues posted by Janicholson on December 02, 2010 at 09:16:50:
What style of PTO do you have? Early tractors had a planetary type. That unit has a small oval cover on top and the engagement lever will latch in both the engaged and brake position. The later tractors had the over center clutch style where the handle will latch only in the brake position.
The later, over center type, is more likely to see this problem. If the bolt that clamps the lever to shaft going into the PTO unit is not tight enough the woodruff key in the shaft can shear off and you will not be able to shift it. If the linkage moves going into the unit itself you may have mechanical problems that will need disassembly to repair.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
