Re: Need Ideas/Methods to Fix Damaged Rims???
Posted by Brownie 450 on December 03, 2010 at 03:53:42 from (66.43.241.198):
In Reply to: Need Ideas/Methods to Fix Damaged Rims??? posted by RTR on December 02, 2010 at 16:45:48:
Welding Man has the best method from strength standpoint. We use 1/16 inch steel strip of the right width & hammer/grind it to fit, & weld it in where the rust is. Then drill a new hole as WM says.
When we are done with implements that sit outside, we jack the individual wheels up & rotate the valves to the top so rain won't run into the valve hole.
