Posted by Andrew Z on December 03, 2010 at 06:27:38 from (64.252.124.88):
Im working on a 450 with a TA, it worked earlier this month when it was warmer and now it slips under load. I could not get it to slip at all in 4th gear going up hill and pushing on the breaks. I checked the rearend oil very milky with about the texture of fresh bulk tank milk, yet coffey color. Two questions first could the water in the oil be causing the one way clutch to slip? Also if that is not the problem what goes out in these TA's, im assuming its this one way clutch when sliping in low range? Fianlly if all the rest of the parts in the TA are fine can i just replace this one way clutch? Im going to drain it and run some diesel though it latter today. Perhaps something is stuck from the water and oil?
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
