Re: Farmall c conversion to 12 volt
Posted by John T on December 03, 2010 at 16:27:19 from (66.244.97.31):
In Reply to: Farmall c conversion to 12 volt posted by burnsg2003 on December 03, 2010 at 15:31:56:
If theres some sort of high resistance short causing a trickle discharge, just changing batteries (and NOT fixing the issue) isnt gonna cure that.
If a battery is bad causing excess internal self discharge, thats true regardles if its a bad 6 or bad 12 volt battery.
Battery tenders are a good way to keep a battery up on a seldom used tractor and 6 or 12's can run down if they set unattended too long.
A little C should start fine at cold temps if the engine is well tuned and you have a good heavy battery and 0 or 00 gauge cables
Can ya tell Im not a 6/12 conversion fan on small tractors lol
But hey its your tractor and your choice so do what turns your crank, Jim or the others have given good advice
John T
