Posted by CharlieNJ on December 03, 2010 at 18:42:21 from (174.57.220.136):
In Reply to: 460 Diesel Problems?? posted by Bud DeLong on December 03, 2010 at 17:57:47:
Bud, The early injector assembly is part# 279263R91, The later injector assembly is part # 310388R91. Early for serial #'s 501 to 9998. Later for serial #'s 9999 up. Click on the link and type 460 in the search block. Looks like the nozzles, pre-combustion chambers, and injector bodies are different between the two. Someone else may be able to tell you if they are rated differently. Best Regards, Charlie
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
