Re: 460 Diesel Problems??
Posted by CharlieNJ on December 03, 2010 at 20:01:38 from (174.57.220.136):
In Reply to: Re: 460 Diesel Problems?? posted by Bud DeLong on December 03, 2010 at 19:38:08:
Bud,
Yeah, I tried the link too, and it does not work. So, try this; Search for the "Case IH" homepage, browse the "Parts and Service" tab, then click on "Search for Parts". A new window will open, at the bottom of that window click on the red letters "right here", after the phrase "Begin your search for the parts you need". Then, type "460" in the search box. Then click on "460 Diesel Tractor" then click on "Fuel System", then click on "Fuel System Injector Nozzle".
There you should see the picture diagram, descriptions, and part numbers. If not, let me know.
Best Regards,
Charlie
