Re: Re: 10-20/w-30 help
Posted by justin on June 30, 2000 at 19:42:44 from (12.34.184.104):
In Reply to: Re: 10-20/w-30 help posted by Redfan on June 30, 2000 at 18:42:59:
The F20 engine is in no way similar to the F30 or 10-20.. The largest bore available for the F20 was 4", while the standard bore for both the F30 and 10-20 was 4 1/4"..
If you check the parts book, you will find the following concerning the 10-20 and F-30:
Sleeve part numbers for both are: 435D
Cylinder sleeve packing ring: 822C
Oil Pan: 499DAX
Crankshaft: 10379DX
Connecting Rod 10393DX
Pistons (that will interchange) 2919D
main bearing (front) 10399DA
(rear) 10400DA
Connecting rod bearings: 8298TAX
10909DX
oil pump: 16206D
etc...
These parts and many others interchange between the two tractors..
Post A Followup
: Re: Re: Re: 10-20/w-30 help
