Re: m hardware in rearend oil
Posted by D Slater on December 03, 2010 at 23:59:50 from (184.15.43.68):
In Reply to: m hardware in rearend oil posted by Mike Bock on December 03, 2010 at 17:08:13:
Only place a M rear doesn't have ball bearings is the pilot bearing on the front of the main shaft. If it looks to be a complete roller the size sounds a little small for a roller out of that bearing. Some did get updated inner roller axle bearings if repaired before, but they are a way bigger roller than you discribe.
